When in SLi
DieHard007
does video memory double like from one card at 512 to 1024 when in SLI or is it just dual GPU
It is dual memory and GPU its basicly 1 and 1 1/4 of the power of 2 it shares memory so 1 card can do less things and its dual gpu for higher resolution gameplay.
no, say if you have 2 cards in sli, eatch with 512mb memory, you still have a total of 512 memory. SLI just kinda switched between the 2 cards for every other frame
In SLI you only get a single card's worth of RAM. The reason for this is that all the data transfered into a single cards' RAM needs to be duplicated in the memory buffers of both cards.
