no seriously, use vinyl dye if you're painting plastic. just clean the part with alcohol, let dry, then spray. let it sit out overnight through cause that stuff is strong.
On smaller parts like that you will want to do only a couple thin layers of paint on them... remember that paint adds thickness to objects, so when you are painting buttons and such don't lay so much paint on that it will stick or not be able to got back together after you paint.
