When I Go To ShutDown, It Restarts...
GummyBear
like it says guys. i got winxp running as os. anyhting i should check for? i kno this is OOT but i really didn't kno where to post this... someone plz help!
TIA!
Its probably actually BSOD'ing when you tell it to shut down. Windows XP by default automatically reboots after a BSOD. Under Control Panel->System->Advanced->Startup and Recovery->Settings, de-check "Automatically restart". Then you can see the BSOD message and start troubleshooting the error message.
TIA!
you prob have a virus...
