When does 370gb = 400gb?
Shameless Liar said:
Who wants to buy a 3TB* HD?
1TB = 10 bytes
Not fair is it? They should really market drives with what their capacaties really are. 1GB was never 1,000,000,000 bytes, and will never be 1,000,000,000 bytes. A little note or disclaimer doesn't change that, but it seems to satisfy the law
1GB = 1,073,741,824 bytes. End of story. (Unless that figure is incorrect. Someone check it. I did the arithmetic in my head)
Umm, no. You just don't know how to count in different bases.
Neither the MFG nor the OS is lying.
One counts in decimal, the other in binary, people ususally think in decimal, and that is what the MFG uses. Computers ususally count in binary, so that is what the OS uses.
Just because you never learned how math works is not anyone else's fault.
==>Lazn
This isnt a new problem... It's just the way it is. Get used to it... My 120GB is only 114GB, and my 200GB is 189GB.. who cares? People still refer to them as 120s and 200s... I don't care... besides there is the disclaimer too.
GLSauron said:
36GB Raptor.
Simple partition, standard XP install formatting.
that is the same number i get, down to the byte.
Well, I don't think it has much to do with different bases. It's a matter of recognizing the situational meaning of the SI prefixes and abbreviations. "GB" might mean 1,000,000,000 bytes, or it might mean 1,073,741,824 bytes, depending on the context. You don't have to know how to count in any particular base to do that.
