Wheels for antec 900
Rydawg5143
I saw a picture of an antec 900 with some wheels attached to it. Anyone know where to look. Google gave me nothing / Want to get my 900 off the ground :(
I find it hard to belive you could not find some sort of wheel via the google. :)
If you don't mind drilling holes, you could get the same wheels at any decent hardware store.
I've used both the 4 screw type and the kind with a post. In the latter case, I found a set that had a threaded post that fit into the existing holes in the case bottom. With a washer inside and out and a nut to hold it in place, the thing went in easily. I did cut the bolt down from the 1 1/4 inch as manufactured to the minimum length that would fit.
I would prefer not to have to drill into my case. The ones i saw that i liked had a big bar the connected 2 legs and the case sat on it. Gues ill have to head to the depot.
