whay arent monitors 16:9
cannondale06
Im sure this has been asked before but is there any legitimate reason why widescreen pc monitors are 16:10 as opposed to 16:9?? It just seems logical that they should be the same as televisions to me. :confused:
Probably because computer resolutions have traditionally needed to be divisible by 8 or 16 (though not so much anymore), and using an odd number in the aspect ratio makes this a lot harder, reducing the number of possible resolutions available in that aspect ratio, and unlike HDTVs which are either 720p or 1080p, there is a need for many different native resolutions in the computing sector, for everything from 1280x800 (e.g. notebooks with 12" screens) to 2560x1600 (30" workstation screens).
It's just one of those things... sort of like "Why did 1280x1024 become the standard rather than 1280x960"? It was used widely on CRTs, most games not offering a 960 preset, just 1024. Then when flat panels started coming out, 1280x1024 was the native resolution of many of them, creating the single instance of a 5:4 display, when it was traditionally 4:3. Now you have 16:10 rather than 16:9, despite 16:9 having been standard for HDTV long before the widespread use of widescreen PC monitors.
There are a couple 16:9 monitors. There was a 17" Westinghouse a while back (the one in the laptop-looking 360 project) and currently Gateway is selling a 17" 16:9 monitor, the FPD1775W. I recently purchased the Gateway because it's small enough to fit in an SKB 3i-2011, along with a 360 (took it cross-country as carry-on luggage).
In general why did PCs go with 16:10 instead of 16:9? The divisible by 8 and existing 1024x768/1600x1200 posited above make sense to me.
One of the reason for the extra space is for control panel when viewing movies. With TV, you have the remote so you don't need the extra space.
I don't mean to argue but, other than tradition.. simple 16:9 leaves you with too few vertical pixels for a lot of things.
I have a 20.1 and a 24" 16:10.. the 20.1 STILL seems short on vertical pixels for certain things (programming and graphics come to mind) Imagine the smaller sizes..and then shave off more to throw it to 16:9.. I would love for there to be a standard.. but 16:9 for tv/movies isnt a standard anyway.. theres that ultra wide aspect quite a few movies are shot in.. There simply is no one fits all solution.
