- Aug 18, 2006
Everyone calls it 21:9, 16:9, 16:10, etc. No rule that it has to be reduced.
We could start calling 4:3 16:12. You think it will make a comeback then?
Because you would only be able to see a tiny bit of the screen at once if you were sitting at a typical monitor distance from a 110" display.I don't understand your point to be honest: why would you have to sit further back?
Most people with multi-monitor setups expand things horizontally. Stacking displays on top of one another is uncommon, and when it's done the top screens are usually angled down.A 110" 8k ultrawide display would be basically a huge screen that can be used as multiple monitor setups, so rotating your head to look at the various parts wouldn't be an issue.
It's a lot easier for people to visualize if you call it 12:9 (4:3), 15:9 (16:10), 16:9, 21:9 etc.We could start calling 4:3 16:12. You think it will make a comeback then?![]()
So?Because you would only be able to see a tiny bit of the screen at once if you were sitting at a typical monitor distance from a 110" display.
Which means that we'll need screens curved vertically and horizontally.Most people with multi-monitor setups expand things horizontally. Stacking displays on top of one another is uncommon, and when it's done the top screens are usually angled down.
I still don't understand the problem, nor from where you took the "practical limit" you're writing about.A 110" ultrawide would be taller than three 27" monitors stacked on top of one another. It would be ridiculous. I don't think you realize just how big that is.
I didn't just pick 55" out of a hat - it's the practical limit for a 100 PPI display without using DPI scaling - and I'm sure that some people would even find that to be too big.
Here it is compared against a 27" monitor.
It's a lot bigger - but not impractically so, when you consider that people are already using 40" 4K panels and setups with 3x 27" panels.
Avsforum CIH is sometimes fun to watch.
