What's your system temp?
Bugalaman
Really a Ugandachick
So, what's your case temps? Right now mine is 19 C, In the summer it gets to a max of 25 C.
I'm just wondering if my computer is cool enough.
Ambient - 10 C in winter, 24 C in summer
Case - 15 C
CPU Idle - 20 C
CPU Full-load - 30 C
my cpu temp is 56 c and system temp is 46 c I have a MSI nvidia nforce delta motherboard and the fan on chipset died already , its only 6 monthes old the cpu fan is fine and the power suppley fans and case fans are all great but what kind of fan do u recommend to replace on the chipset ? Are theses temps way too high?
Current temps as checked with Sandra:
28*C system
23*C CPU
(And no, thats not backwards) :)
idle temps:
load temps:
-as you can see, case temps between idle and load only vary by one degree. not too bad considering my system is in a SFF case.
im sorry.. im just annoyed about all the "is my computer too hott threads"
and more on that.... this guy isnt near 50C or anything.... he has very good temps for air cooling
His window has to be open because my pc has never come close to the 20c's or even low 30's
Currently:
CPU die: 50°C
CPU socket: 53°C
Case: 26°C
Harddrive: 47°C
CPU does low 30's usually at idle, depending on case temperature(which fluxuates between 24 and 29'C), and at full load I've never seen it above 39'C regardless of case temperature. If I could figure out the garbled mess MBM puts out into the xls log file, I'd make a scatter graph of CPU temp vs MB temp, and CPU temp vs CPU load :p lol
Oh, barton 2500+@3200+(11x200)@1.75v
mine's been in the mid to lower 40's. highest now is normally 47-48. installing the ceiling fan has helped immensely.
