Whats wrong with my comp?
Alright, heres the story. I need help, PLEASE!
So my dads power supply MELTED last week. Yes, Melted. Smoke, burning smell, melting stuff inside. The computer was infact USEABLE for short periods of time after the meltdown. I put a new power supply in it, and then it dies out (no post or hard drive noise etc). I got a new mobo/ram for it from PCW (no name brands).
I put everything in, start it up, and theres No signal from the monitor. The mobo has onboard, tried That, the GF4 ti4200 that was in the comp when it melted, and a GF2 that I had chillin out. No combination worked.
The hard drives spun, it had traditional boot noise, but I got No signal.
I just dont know whats up, if its a bad AGP slot, or if its the mobo, the ram. I have some parts to troubleshoot the problem with, but I can only go so far. someone please lend me some insight!
<3 always
UCM
What brand is the board? Have you tried checking the manual for the board to make sure that you've done everything right. Hooked up all the needed connectors? Is this a Pentium II/III/4 or is this an AMD based system?
If the video is onboard than likely it should work. If it doesn't some motherboards actually need a jumper or dip switch changed to use the AGP slot if it has one. This is not normally the case with really new boards but is with older ones. Again more information would be usefull as to the system configuration.
Also do you have a voltmeter or multi-meter and know how to use it? You could check the PSU voltage and make sure that you are getting enough voltage to run everything.
ah, sorrry about that. Its a 2.66GHz(533 FSB) processor, and a PC Chips M963. I looked through the manual, and didnt see anything about a jumper for AGP > onboard.
Basically, Im thinking its either a bad AGP slot or my power supply.
Need any more info?
Does the board beep when you start it up? It should beep when its done initializing the BIOS after POST.
