What's wrong here?
smell
Im having a problem with my other computer and im pretty sure it's my mobo. It won't detect my video card or my headset w/ mic. ASUS P4P-800 intel i875 chipset. No idea what to do, any help is greatly appreciated.
Have you installed the proper drivers?
I don't know if that board has onboard sound/video. If it does, you need the motherboard drivers. If you have an agp/pci video card, go to the website of the cards manufacturer and do get the correct drivers there. Same for sound card.
P4P800=i865PE chipset.
P4C800=i875P chipset
Your confusing me. :confused:
be a lil more specific? is it a AGP and a PCI? and Is the sound Onboard? if so, is it Switch on Enabled In the Bios? Cause if it isn't, it wouldn't even load up in windows. IF yer sound is Onboard, is it set so that the onboard sound is NOT using the Mic in port as something else? such as subwolfer port? it can easily be changed if you make yer on board sound from 2.1 to 4.1 to 5.1 surround sound, at which all the ports are used for Output, and there is No Input or Mic port.
hope it helps.
sorry, typo there it is an i875 chipset
I should have mentioned that the computer had been working fine for months, then one day the monitor just suddenly turned black. I just tried the video card out on this computer, and it didn't work so I think I solved that problem, i need a new card.
The sound is onboard, and I think I'll be able to fix that once I get my monitor back up.
Thanks for the help.
