What's up with this 6950
obi-kun
It's the PowerColor AX6950, which is retailing for $199.99. Is there some reason this card is around $30 less than all the other 6950's? The closest priced 560 TI is ~ $210, and the 6950 beats it a little bit. Is PowerColor trying to clear their stock?
I'm wondering because this is the price point the 6930 is to be releasing at, if you can get a 6950 for $200 what's the point of buying a 6930 for anything more than $180.
Thanks, I haven't been really keeping up for very long and the power color was simply strange when compared with everything else.
Thanks for the link, that one is a better deal if you're looking into Dirt 3, but isn't there a thread about how bad XFX's customer service is?
And thanks for the heads up on the 6930, didn't know it was Europe and Asia only.
The XFX card is reported to be rather loud, dual-fan cards are usually quieter.
If you are referring to [thread=1652910]that thread[/thread] IMO the OP's expectations are unreasonable, but that's up to individual judgement.
Might be a little more than what you want to spend but newegg has Sapphire 6950 2gb for $239.99 after rebate.
I picked one up earlier this month and it is awesome! With the flip of a switch you can switch to a 6970 bios which unlocks the shaders from 1405 to 1536, then I just used Sapphire's Trixx program to overclock it to match a 6970. I've logged a ton of BF at 1920x1080 everything maxed out... it runs it awesome and doesn't get too warm(52c was the highest i noticed it get).
http://www.newegg.com/Product/Product.aspx?Item=N82E16814102954
Thanks for the idea, but I'm probably going to just build a new tower somewhere down the road. It's an idea though if I can grab them while the 7xxxx series are running around.
What program(s) are you using to monitor temps? Is that temp during load and OC'd? Imrunning my XFX at 900/1375 and was seem to hang around 70c during load. Just curious, thanks.
