Whats up with Prime95?
RP_JAKE454
ok i just got my new heatsink and i was stressin my cpu with prime and after...about an hour and a half...i stopped the test and it said torture test ran 4 hours and 4 minutes...this isnt right..whats up with that?
did you change the windows clock while you were doing it? i reset the cmos when i changed my hs last and forgot the clock, so in windows i changed it forward a couple of years while prime95 was running, and behold... my computer was so fucking stable i could run prime for 30000 hours without it failing
