OK, back in the day, we only had a CPU temp to go off of. Rule of thumb was you didnt want this to go over 65c. Now we have diodes in the cpu cores them selves. Is it still safe to go by the old tried and trued temp method, or should I focus on core temps now?
The reason I ask is I have a X3550 (Q9450) and its clocked at 3.72ghz @ 1.4v in the bios. It shows 1.37 in cpu Z, and can go as low as 1.33 under full load.
Anyway this is the temps I get
If I go off of the CPU temp I am fine, as it idles at 35-38 and loads at 60-62. However, my cores idle at what you see above, and under full load get damn near 70c. Is this OK, or should I be worried?
also, real temp shows my temps 10c lower then rightmark does. Which should be believed?
