Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
A quick question. There is a cable coming out of the PSU, green and yellow with a forked metal piece on the end. What is this for? None of my guides mention it.
Before we say for sure, what is the brand/model of the PSU. I'd hate to arbitrarily say "ground" when it could be for some proprietary component elsewhere.
but green is a common ground color
and having a metal end suggests that it is for electrical contact
you dont generally see them on supplies that have an unpainted metal enclosure,
since the enclosure itself will be the ground to the case,
but with painted supplies and cases its a good idea
odds on favorite its a ground, the other way to tell, find the other end
Find a nice tight chassis screw somewhere, loosen it a bit, stick the forked thingy under the screw head and give it a good tighten.
If you really want to be slick, take out the screw and go to a hardware store or your junk drawer and find an nice sharp toothed washer and place it between the fork and the head of the screw.
