Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
The idea was to stop scrolling text in DOS, basically. Theoretically if you pressed Scroll Lock it would cause text to stay within the window, meaning if the text scrolled down - as it filled the screen, like holding Enter would cause the prompt to jump to the next line, the next, etc, then "scrolling" off screen as new text replaced the old.
What you'd end up with is text that got to the bottom then started from the top and went back down again, sort of "locking" it into the given frame of the display. I used it one time in all my years, just once, and it did work, but that was way back around 1983 or something, never saw it as being useful since it overwrote what I was tried to read just as badly as having the content scroll offscreen. Either way I couldn't do what I wanted to do sooo...
