what are we talking bout here? looks like motherboards. What brand?
I would prolly say that it is a revision lookin at what info you gave. Revisions are usually more stable & o/c better. But again give a bit more info.
going to gigabyte's site will give alot of info. I believe this is what you are looking for. the pro has ide raid, onboard lan, sata, dual bios, and firewire.
EDIT: Cant get the link to work right. So just copy and past this url in your broswer and it will take you to the comparison page.
http://tw.giga-byte.com/motherboard/products/comparisonsheet_chipsettype_nforce2+ultra400.htm
EDIT2: Links are being really wierd today. When you past that. It will put a space before comparisonsheet(shouldnt be there) and not pas in the ultra400.htm part. If someone can fix my link i would appricate it.
The pro=6layer pcb= everything controlled in cmos, multi/fsb/voltages, ect.....
The pro2=4layer pcb= Dip swithces for multi, limited cmos controlls
The pro=all cpu, voltage,mem timings,fsb, multi, all done in bios
The pro2= dip switches
The Pro=adjustable cpu voltage up or down
The pro2=overvolted cpu voltage at 1.7v instead of 1.65 unchangeable
The Pro=nvidia apu -aka- soundstorm
The pro2= no soundstrom
We have this wonderful modded bios for the pro, great for those who overclock
**Pro is discontinued in favor of the pro2, this is seen as a product seperation as the pro and the 7nnxp are allmost identical with the execption of the giga lan and the dps.
If youre choosing between the boards you asked about, you definately want the pro.
