Whats the difference between...
Aside from one being Open Box and the other new? PCB color and no flaming heatsinks.
-bZj
how do you guys feel about open box mobo's then? I don't know if its worth shelling out twice as much for a new board.
What is this board for? What's your budget? What features do you need on the board? Give us an idea of your needs and we can recommend a board that will fit.
Go with the open box XBX2 if you want to OC.
For OC'ing, there are better choices IMO; one of them being the Abit IP35-E from mwave for $91 - $20MIR. But it really depends on your needs.
Cheap and very stable is what I'm going for. I am currently running on a P4 setup and want something a bit zippier. I don't game very often, but I do multi-task quite a bit.
This is what I'm thinking so far:
CPU: q6600 (Once ClubIt gets it back in stock)
Mobo: Bad Axe 2
Mem: 2GB GSkill (2 x 1) http://www.newegg.com/Product/Product.asp?item=N82E16820231098
I will be re-using many parts, so my upgrade budget is around $500
Oh, and I do not intend on OC'ing. I just need it to be fast and stable.
Mobo: Bad Axe 2
If you're not OC'ing, then you don't need the BadAxe2 unless you want Crossfire. And even then, the X38 chipset would be a better choice, since it replaced the 975X.
What features do you need in a motherboard, aside from stability and quadcore compatibility? Firewire? RAID? onboard graphics?
Basically, it needs stability, quadcore support, and 8gb memory support. I do some audio work so the memory is important. I would also like to keep it around $100. I do not need raid support, firewire, wifi. Onboard video could be a plus (just incase my video card dies at any point) but isn't required.
I have XBX2 and a q6600, just order a ABIT IP35 PRO..
the XBX2 is a good board but seems to have limits for OC'ing the Q6600
My XBX2 ran my E4300 all day at 3.2 Ghz but cant get my Q6600 over 3 Ghz
