whats the difference between xt or xt pe?
Brucee
Like the Ati X800 Xt sapphire
or the
ati x800 Xt pe?
which one is better and does anyone have pics of this so called Pe? or is it the same as the x 800 Xt?
or the
ati x800 Xt pe?
XT pe has faster clock speeds. Other than that they are the same thing.
o
k the X8000 Xt not the pe is the 16 pipe 500 core and 1000 speed ? am I correct?
x800XT = 16 pipe, 500 / 500
x800XT PE = 16 pipe, 520 / 540 (I think)
They just have different clock speeds, no other differences.
I actually purchased a blue oem version of the sapphire x800xt from newegg and it turns out it was just a disguised platinum version, so all I did was overclock it to the platinum speeds 520/560,
X800 Pro is 475/450 12 pipe
X800 Pro VIVO 475/450 12 pipe (but is really an XT-PE in disguise in most cases)
XT is 500/500 16 pipe
XT-PE is 520/560 16 pipe
I bought a VIVO and flashed to XT-PE with 16 pipes, it runs 540/580 *all* *day* *long* W00T :)
so PE = Plat Edition?
I bought a x800pro this weekend , trying to decide if i should shell out the extra 100 stones for the XT PE.
d.
