whats the difference between these two dvd burners?
InCogneato
the first one has an E-IDE interface and the second only meets IDE spec, and the second one also incorporates Lightscribe technology
i would get the cheaper one, Lightscribe is nothing you want to pay for
PIO Mode 4 and all that other jazz are old IDE specs that you hopefully would not be using anyways, PIO is slow as molasses and would suck horribly, it's just an old spec that any drive supports basically, it would be the same as saying a USB 2.0 device also supports USB 1.1......it's just backwards compatability
you have to pretty much ignore Newegg specs as they are usually wrong in one area or another, you should always check the manufacturer's web site and look up the model numbers and get the true specs from them
