whats the differance? help!
ubern00b15
between a SN41G2V2 and a SN45G i i want to put to sata drives in and raid them and i planed on buying a raid card and it needs mcp-t and needs to be overclockable, should i even get a shuttle or should i get one of those biostar ones, i know the SN41G2V2 has a 250 watt psu........help me out
The SN45GV2 also has a 250W psu. The only difference is the SN41G2V2 has onboard video, thus it's a bit more expensive. Due to the onboard video there is also an extra 40mm fan on the northbridge, while the NB on the SN45 is passively cooled.. It you want to go above 400mhz it may be easier with the SN45G2 series. Lastsly the design is different, G1 case vs G2 case.
