What's the differance between....?!!
Mohjarr
Hi... Anybody know what's the differance between "Scythe Ninja" & the new one that called "NINJA PLUS" cause I saw both of them the same price on newegg although the "NINJA PLUS" come with 120mm fan ??:confused:
AFAIK, the PLUS just comes with a fan, where the normal one doesn't. I may be wrong on this, but I think thats it.
so why both of them the same price on newegg? & why a company like Scythe whould make another product the same exactly like one of it's most successful product & call it PLUS????!!!!
I see both of them look the same exactly as you said but I think maybe there is more difference. :confused:
You are correct.
Not sure why. When I bought mine on Newegg, the PLUS was about $5 more.
perhaps some ppl have 120mm fans laying around....good choice in HS btw. :D
this is a little off topic but related,
I have the Thermaltake SI-92 w/ vantec tornado 92 mm fan on it.... who the scythe Ninja lower my temps?
the two kits are identical, save the PLUS version includes a 120mm fan. that's it. Newegg is just weird for pricing them the same. btw, that price for the PLUS is pretty good. i picked up the kit w/o a fan at jab-tech.com for $34.95, and added a Yate Loon for 4 bucks more. i'm happy. great heatsink!
