What's the better audio solution?
Valnar
I'm building a new PC for my brother while utilizing some of his older components. It's going to be an Intel Core2Duo in a P35 chipset Gigabyte GA-P35-DS3R motherboard. The motherboard audio is the Realtek ALC889A HD codec which probably represents the best of onboard audio and his existing sound card is a 4 year old PCI Sound Blaster Audigy 2. My guess is sound quality-wise, the Realtek is probably on par if not slightly better. But for compatibility and EAX, is the older Audigy2 better for games? Or the Realtek?
-Robert
Audigy will give you 128 sounds at 24bits while the RealTek onboard will give you a maximum of 64 sounds.
With the new RealTek HD audio I am not sure how the situation has changed.
