Delicieuxz
- May 11, 2016
I have an API A2D microphone preamp interface that I need to get connected to my PC for music recording. I bought a Creative Labs Titanium HD sound card, because it supposedly has coaxial SPDIF, but I haven't been able to get it to work with that sound card. I just get this screeching noise coming through the speakers when I have the API interface running:
View: https://vocaroo.com/1cn67SeJ36Ie
In the clip, I switch the API A2D control switch through the various bitrate settings, which is when the frequency of the noise changes.
In that clip, when I sets the API A2D to 192k bitrate, the screeching noise wasn't there. But after changing the clock speed in the Creative Labs software, the screeching sound started occurring on the 192k setting, as well. Also, when playing with the software, sometimes the screeching would not happen on one setting or another - but it seemed to be random which bitrate setting the screeching wouldn't be on, it didn't correspond to what the software was set to. And when it wasn't making that noise on a particular bitrate, I tested playing audio into a mic and through the A2D, and no audio was coming through my PC speakers, even though the API A2D preamp and AD meters appear to be receiving the sound normally.
After enough playing around with the bitrate in the software, I got it so that both the software bitrate and the API A2D bitrate are set to 44.1k, without that screeching noise coming through the speakers. So I tested it in my DAW by monitoring a track with the input source set to Digital-In L. But no audio came through the speakers. Then, when I set the input source to Aux L, I got that same digital screeching noise coming through the speakers.
View: https://youtu.be/2pJo073_CCA
The API preamp interface worked with my previous PC, which had an Auzentech Prelude sound card with coaxial SPDIF. But I can't use that sound card with my new PC as the Auzentech sound card is PCI, non-express, and my newer motherboard doesn't support that.
Coaxial SPDIF is kind of an outdated connection that isn't supported in newer stuff, which makes it tough figuring out a good connectivity setup for my API interface. The Titanium HD is supposed to support coaxial SPDIF, AFAIK, yet it isn't working for me.
One solution I've thought of would be to get a sound card that supported optical SPDIF, and then use and adapter to convert from coaxial SPDIF to optical SPDIF. The only current Creative Labs sound card which supports optical SPDIF-in is the AE-9, which costs half a grand. It'd suck to pay that just to connect my interface.
Another solution could be to sell the API A2D and buy some 500-series API preamps and a good AD converter. But that could end up being expensive and I really like the API A2D's features and design.
Another idea I've had is modding the API A2D's outputs, to give it ADAT, USB, or whatever works output. I don't know if that's possible, but if it is, it'd be nice to do.
Rear and front of the API A2D:
The Titanium HD's features:
