Some users have recently had their accounts hijacked. It seems that the now defunct EVGA forums might have compromised your password there and seems many are using the same PW here. We would suggest you UPDATE YOUR PASSWORD and TURN ON 2FA for your account here to further secure it. None of the compromised accounts had 2FA turned on.
As stated in title whats the best temperature read program for your CPU because the Asusprobe program that came with my mobo isnt reading my cpu temp correctly cause its 5-7degrees cooler than what is read on my bios. Any suggestions?
Motherboard Monitor 5 or Speedfan both work fairly well. There are several others out there that would work also. Just keep in mind that none of these programs are 100% accurate.
A temp reading app is only as good as the board/CPU thermal probes/thermistors which I'm sorry to say are notoriously inaccurate. They are good for referrencing changes in your system's temps, but not so much for comparing to others.
alright thanks for your input guys. I tried out Motherboard monitor 5 and there wasnt a way to turn off the taskbar thing. The only problem i have with the Asus probe i have is that it only reads the Cpu socket temp. when i checked 2 other programs it shows that was my cpu socket temp too. and my Cpu diode temp was about 5-7degrees hotter. My question is can those programs run in the background so i can check temps whenever as apposed to launching the whole program
thanks!
