If you mean currently it wouldn't make a difference. The reference cards are likely sourced from the same supplier (possibly Sapphire) or possible two suppliers. There is a preference for Hynix memory over Elpida memory for memory OCing at the moment but there is no grantee you will get one or the other. The only guaranteed physical difference between the brands is the sticker used for branding.
Just pick whoever you feel has the warranty/service and price most appealing to you.
not sure if I necessarily agree with that ^^^
I have really good luck overclocking EVGA, and MSI cards. I have had fairly good luck with an Asus DCUII Top Edition 680 that Ive had as well, but a refrence model was so-so.
Yeah I just got 2xXFX290s before that coupon expires from newegg.
I'm also reading those 290 unolocked to 290x. I should definitely give a shot once it comes.
I like Sapphire.Know that Powercolor has no VRM sinks.
