What's the best MB + CPU combo (AMD)
I'd go w/a 3000+ Venice S939 and a DFI Ultra-D mobo myself.
(thinking about buying just that)
The DFI board along with the highest a64 you can afford. The 3000+ venice definately has the best value though.
I would spend a lil more and go DFI-$130 and a 3200+ venice-$190
If you go with a 3000+ venice you run the risk of getting a crappy overclock due to binning(although there is no gurantee to overclocking)
Although you could go DFI+3000+ for 250(there is a good deal on the 3000+ in the deal section) and pick up a nice mouse or soundcard.
the dfi lan party ultra d seems to be able to ov3erclock a "crap" core winchester about 260mhz more than my asus can @ the same volts- on the venice cores the DFI still had an edge of about 100mhz
i got one of those chepo $117 shipped venice oem's from ewiz
at one time they had the 3200venice for like $146 shipped
as far as overclocking the 3200 is a little better because of the 10x multi-
but from what i have seen--the venice cores top out just under 3000mhz actual on air regardless my 3.2venice 2.78g my 3000venice 2.93g --best overclocker i had was the early winchester 2.98g--worst the late winchester --2.5g asus and 2.69DFI-ultra d
be aware that the DFI has some killer voltages--and they do kill stuff like ram and cpu's if you get crazy with it--otherwise a fine mb with bios 618 beta or above-- :cool:
DFI lanparty ultra d & chepo 3000 venice--for overclocking otherwise there are lots of nf4s that overclock some and game with good value. :cool:
Thanks guys!
Okay, I know this says alot but, here goes... (yes, I've been out of the hardware scene for a while)
DFI is that the brand or is that the model? I think I'm gettin' this one, any link?
3200+ Venice it is.
Also, what's a good memory for the board?
Thanks again! I really appreciate the help.
http://www.newegg.com/Product/Product.asp?Item=N82E16813136152 Thats the DFI mobo. DFI is the brand
http://www.newegg.com/Product/Product.asp?Item=N82E16819103535 3200+ venice
DFI says not to go with value ram but I think you are fine with it. Heres what I ordered with the above. http://www.newegg.com/Product/Product.asp?Item=N82E16820146190 Other people will probably have better sugestions on the ram.
With the AMD that you are getting the memory doesnt have to be a champ to get a good overclock.
For raw performance with no upgrade path it is cheaper to get a socket 754 boards.
The 3400+ newcastle and the 3700+ for socket 754 are both 2.4 Ghz CPUs and the higher clockspeed beats the bigger cache (the 3400 only has 512K) and dual-channel memory RAM in almost all cases.
Thanks for the link Shakezilla--
Okay, I just read the specs on this board, and no AGP -- Oopsy.
Can someone recommend a PCI-E that wont break my bank account, and is better than what I have now (9800 Pro)...
Thanks!
Hmm, I'm reading through the reviews at newegg about the DFI board, and one thing that always comes out is that it's not for newbie...
I'm no newbie, but I also don't have the time to mess around with RAM timing, BIOS, etc.
So, should I be expecting to tweak the board before it actually boot up? I'm not really not into O'c either,all I want is a board that will boot up to it's rated potential at default.
My last Oc was the legendary Celery 300A that goes to 450 like it was really a 450. Yup, that was looooooooong time ago.
Any other board?
Thanks!
if you can update a bios --then you can build the DFI--
there was a problem with the bios on some of the first mb shipped--but with bios 618 beta or above--you can just about set the ram on auto and overclock away--providing you have set the ram divider , hyperthread and so on--if you have built a computer before and can flash it to a new bios--then it shouldn't be too difficult
if you have problems getting a toaster out of the box and working--then it might be a bit much--lol :cool: :eek:
Dont get the DFI ...more trouble than worth it...just my opinion...and if something doesnt work dont count on a quick fix, too many issues with hardware compatiblity etc etc...i rma'd my dfi lanparty sli-dr and shelfed it...i rather come home from work to a working computer than try and figure out how to make everything work without a hitch...lots of problems with memory compatibility also...read the dfi-street.com forums beforehand and get a taste of frustration.
the x800xl is decent value for the $$$--last week monarch had the retail package on sale for $250
every once in a while you'll see a x800pro vivo on the referb rack at the egg for less than $200.
the referbed 6600gts go for about $130-- pretty good videocard for the $$ as well. :cool:
What would be the point of buying a DFI mobo and putting value RAM in ? Just get OCZ Gold for about 130$ if not the value RAM Ive heard thats actually good is the Kingston.
