I would not spend 900 on a 22" monitor... I would rather get a 42" Sony Bravia or something along those lines. Size does matter... Let me tell you, I could care less if the my enemy's brown pupils are 1.579% not brown... As long as they are big enough to hit =)
I would get a dell monitor.
Which means they'll be even more ridiculously expensive.^^^
Yeah, I've read somewhere that Eizo was going start using IPS panels on some of their models.
Wow, the EIZO FlexScan S2242W has a 5 year warranty! The HP LP2475w has a 3 year, and the Apple only has a 1 year. The only benefit of the Apple is that it has built-in iSight webcam and mic.
becuase you pay a price more than double of an equivalent monitor of other brand.
4. Target market segment: snobs and noobs.
- usually a better kind of TN panel, that also do not turn into inverse looking at from below;
No, there aren't. Some TN panels don't invert when looking from below, but they all get darker.MaZa said:Are there TN panels that do not have vertical gamma shift?
Their FlexScan range is not intended for professional graphicians, for whom there is the ColorEdge range with advanced IPS panels, and a bunch of additional features.They do a lot of research on color accuracy, and it's obvious they put some thought into their monitors, but they waste all that effort by using S-PVA panels. What good are all those features when the viewing angles distort the gamma on different parts of the screen even when you're sitting in front of the monitor? I don't understand how so many "professionals" are oblivious to this.
It has the vertical gamma (and what else) shift, of course, just they do not turn into inverse.What!? This requires clarification and fast. Are there TN panels that do not have vertical gamma shift?
I wouldn't call the features I listed in the #16 nothing special. Actually, I won't buy a monitor that lacks them, and most other vendors' monitors do so. Those that have them are usually not that much cheaper...Eizo's good if you get their high end models. Otherwise nothing special.
Probably the EV2333W will utilize the same C-PVA panel as the Samsung F2380. But I'm almost sure it will perform better in Eizo's hands.The EV2333W seems to be slightly cheaper, 23" 16:9 PVA, but it won't hit Europe anytime soon (and is one hell of a UGLY looking monitor!).
This is a combination of randomly selected words...if you are serious.Think of precise gamma-correction with 10 bits of precision...
No, it isn't. But I won't go proving it before you properly explain your opinion...This is a combination of randomly selected words...if you are serious.
A good joke otherwise.
psyside - sorry to disagree with you (again) but Eizo S2242W = £430, Del 2408 - £400-£440 depending on where you buy.
Eizo has better warranty and an internal 10 bit LUT, the Dell does not plus the Eizo is using the very latest spec S-PVA panel which is honestly not bad at all. Using a control managed app the 'black crush' effect is almost zero. We've discussed the the gamma shift elsewhere but then the Dell suffers from that also
Danny B
Danny B
You are comparing a 24" panel to a 22" panel. To most people that isn't exaclty apples to apples. How much is the 24" Eizo? I couldn't find one under $1000 in Canada, that does put it about double the Dell 24"
Point taken on the warranty but 30,000 hours back light time equates to 16.44 hours a day over five years and I don't have my monitor on that much! I work and sleep also.
As to the screen I know its a 22", I've got one! The Eizo does however run at a native 1920 x 1200 so you are getting the same workable real estate and resolution as a 24" just in a smaller package.
Personally, I have to sit quite close to my screen so I find this an advantage, a 24" is a little too big physically but I do like the higher resolution.
So I guess I am comparing apples with apples but maybe a nice juicy Cox with a Golden Delicious
Thanks
Danny B
