What's slowing me down?
KevC
So I've got a
Newcastle 2800+
NF3 board
1gb PC3200 DDR (single channel)
120gb Seagate Barracuda SATA
FX5900XT
I do mostly Photoshop.
I take all my photos in RAW, and when I browse them in Adobe Bridge, it takes forever. These are 6-8MB photos each, uncompressed to 16bit becomes ~50MB TIFFs. Opening them takes a while but while they're open, photoshop's pretty quick.
The most painful thing is to wait till all the thumbnails load. What can make this faster? More RAM? Or a faster HDD? Or maybe a faster processor?
What's Photoshop most dependent on?
I can see no reason why your current specs cant run Photoshop as well as you want.
I can load 60mb images in Photoshop within 3 seconds but then again I do have a 3500 processor.
Photoshop needs a fast processor and a large amount of ram to run well, you have both so what I suggest you do is go to your preferences in photoshop and increase the memory usage. Play around with the settings... I let Photoshop use 60% of my ram.
What version of Photoshop do you use? When I moved from CS to CS2, I saw a 50% increase in speed when loading custom fonts, brushes, styles and gradients.
If that doesnt help, there is useful information here http://www.adobe.com/support/techdocs/318243.html
what's the rpm on your HD... You might consider getting a faster one if the one you have is slow.
Loading the photos into photoshop isn't the problem.
It's generating the thumbnails for ~50 files in the folder, each 6-8MB each. These are RAW compressed, and uncompressed they are up to 50MB.
I'm using CS2 and it's a 7200RPM HDD.
Photoshop is extremely RAM-intensive. 1GB should be fine, but you might want to look into another 1GB stick. Then again, your CPU is rather slow as well. Maybe you could OC it a bit? I doubt it's the HDD...SATA is very good, and Photoshop doesn't depend on the disk except for scratch.
Have you run adaware and those sorts of programs to make sure you aren't being bogged down by spyware?
Check your proccesses to see what all is being run. And whether you can stop any of them.
