What's normal core temp for a 6800GT?
ZeroBullet
My BFG 6800GT OC has been having a problem with overheating while playing WoW, causing my whole computer to crash. What are normal temperatures for these cards, and what can I do to maybe clock it down to normal 6800GT speed?
I've been having the EXACT same problem. I had to mount an 80mm fan underneith the card blowing air up at the cooler, and keep my door off. If I leave the door on, it overheats.
Normal core temps are 60C idle, 75ish load. With the door off, and the fan blowing straight up at it, my cards been maxing out at 81degC, which is still high =/
Edit: By Halifax, do you mean Atlantic Canaduh?
Yep.
The only hope I would have for additional cooling around the card would be one of those PCI slot coolers, dunno how well they actually work.
Thats real classy! I like your style. :) :cool:
Actually I'd stay with that approach but make a small frame for it to sit on that you can remove with say a small bit of velcro. Perhaps a 120 to 80mm adapter? I might have a go myself.
Its not like we really need PCI slots anymore (well I dont).
What difference would I get between the stock GT OC cooler (it's the custom 2-fan one) and an NV Silencer 5?
The NV5 blows the hot hair out the back of the PC, which kicks much ass. I've got one on my own 6800GT, overclocked to 416/1100, stays about 52C at idle and 67C at load. Also have a SilenX 80MM side fan in my Antec Proview case blowing on it.
The msi one with the copper cooler idled around 55c or so for me.
ZeroBullet said:
I'm idling at 65 right now :\
Guess I'll order one.
Order some Arctic Silver 5 to go with it, works a lot better than any other CPU paste on the market.
I have a leadtek 6800 gt /w the fan screen off, a coolermaster praetorian case /w a custom installed side case fan, and a vantec spectrum fan card under it and it works like a charm. 49°C idle, and a max of 72-74°C or so load. Also I have the pci slot below the card open and the one above it open.
Mine idles at approx 66C and under load reaches around 80C+
Its a Gigabyte nvidia reference style.
