whats needed to "Clip games" using nvidia?
Dan
system is a
ryzen 5600x
16gb ram
rtx 3080
1tb OS SSD
512 Gaming SSD
3440x1440@144hz
I want to buy a HDD where I can offload clips from COD + other games. will a traditional 3-4tb 7200 rpm drive work just fine. assuming clips can get large fast.
system is a
ryzen 5600x
16gb ram
rtx 3080
1tb OS SSD
512 Gaming SSD
3440x1440@144hz
platter drives struggle to keep up if you are doing bitrates above around 100,000kbps.
if you stay under that for bitrate, you should be fine.
Nvidia's shadow play has a clipping/highlights feature built in. However, the quality isnt as good as recording In OBS using the StreamFX plugin.
StreamFX also supports H.265 recording. (although it can be spotty).
