Whats Holding My System Back?
EviL-aLphA
Hey guys..
i recently upgraded my computer, and kept parts of the old build, and i am wondering what is holding my system back the most currently..
Specs
Operating System: Vista 64bit
CPU: Intel Q6600 (G0)
Motherboard: Gigabyte EP43-DS3L
Ram: 4GB of G.Skill PC-6400 ram (F2-8000CL5) running at 5-5-5-15
Graphic Card: HIS Radeon HD4850 (512mb)
Sound: Stock Realtek HD mobo sound
System Memory: 500 GB Samsung Sata2 drive & 320GB Maxtor Sata2 drive
i have been considering to upgrade to 8GB of ram, but other than that im not too sure what else i could do or what is holding my system back from peak performance.
also what are SSD drives for? i have seen a bunch of stuff about them lately but im not too sure whats so great about them or what they would be used for?
thanks guys
What are you doing that's making you feel like something's holding you back?
other then overclocking the q6600.. i see absolutely nothing in there that would be holding your system back.. either you have just grown to impatient with the growing technology.. or theres something else wrong..
Holding you system back, for gaming? Probably your gfx card if gaming above 1680 x 1050
good questions here, the main ones to answer are,
what size monitor and resolution are you running?
what games/programs are you running that make you feel held back?
what psu do you have in the system?
what case do you have? fans?
Is the cpu overclocked?
nothing really holding it back its well balanced possibly sound card could do with a little investment
Doesn't seem like anything should be holding you back, unless you feel as though it can't handle what you need it to.
Also, do you have an aftermarket heatsink? I would suggest overclocking that Q6600 to get more juice out of it.
Thats the question to answer.
eg... gaming? vidcard upgrade. encoding/transcoding? storage upgrade and CPU OC. multi-tasking? CPU OC or upgrade. multiple VM's? RAM upgrade. 3D rendering? vidcard upgrade, RAM upgrade, and storage upgrade.
thanks for all of the reply guys..
maybe i wasnt too clear, my system runs fine, games run well (most of the time), but sometimes its a little sluggish... I was just wondering if any of my specs are a little outdated for my newer hardware (my cpu and mobo upgrade)
I just bought a Samsung 226BW monitor and using 1680x1050 resolution.
I mainly game, surf the net (10+ tabs open on firefox), rip CDs onto my computer, listen to music and watch movies...
i just overclocked to 3.0ghz, i got a xigmantek (i think thats the brand) heatsink and it does very well....
i like the build but i was just wondering if maybe the motherboard or hard drives were maybe limiting my system from utilizing my cpu and graphic card to the fullest?
I don't think so.
What do you mean by sluggish? I can't see any reason why it would be sluggish in games at 1680x1050.
When was the last time you reformatted? I'd consider doing that; I run 1680x1050 with a 7900GS, it's not fast at all by todays standards but it still drives the resolution pretty well. It could just be all that junk that's been building up for a while on your hard drive holding you back.
definetley listen to pc....defragmenting could make a huge dif, or better yet format if you can
Reformat sounds like a good idea if you have been running teh same for a year or more.
