I'm looking for a new pair of CRTs (started out with a KDS 19", picked up some random CTX 17" that's starting to die), and I want to go big.
First though was a pair of 2001fps, but I have PLENTY of room for CRTs, so the LCD space saving isn't an issue. Also CRTs are (generally) still cheaper than LCDs, and I will be doing some gaming at lower resolutions. Enough reasons for me to stick with CRT.
I do want at least 21s though. Need to be able to do at least 1600x1200 all day long, preferably a higher resolution (yes, I can use 3200x1200 without a problem). Obviously I want a sharp image, good colors etc.
Primary purpose is for everyday desktop tasks, and programming. I can have A LOT of stuff up simultaneously when programming, and it's nice to be able to see it all at once, so the higher the resolution, the better.
For 21s, how hard is it to drive them harder than the "standard" 1600x1200 that they recommend? Most list a recommended of 1600x1200 and a max of 2048xwhatever. If I could run them in between that that'd be fine.
Any particular suggestions?
http://www.newegg.com/app/ViewProductDesc.asp?description=24-116-234&depa=0
I was looking at this, but the only thing that attracted me to it was the recommended resolution being so high.
