What's Goin on?
i have a AMD sempron 3000+ on a biostar NF4 4X-A4
i'm trying to OC. i can OC up to 2.1ghz anything after that and my comp freezes after whille. my guess is i need more voltage? when i go into my bios i can't find anything that lets me increase my voltage.
also wtf is wrong with my speed fan? take a look. http://server2.ihostphotos.com/show.php?id=49524
the only thing that is moving is temp 3. top two stay at 127C (wtf?) and bottom ones stay at 40.
mobo = pos?
First - before you start upping the fsb make sure your agp/pci is locked, otherwise ur raising the speed the hdds work at and thats very risky
Second - it may freeze because the ram is at the limit, test the ram with memtest (check the link below)
Third - try everest for temps, etc (check the link below)
how to test http://www.ocforums.com/showthread.php?t=418387
Merry Christmas !
D
