whats cheapest mobo?
Nick_Leo
im planning on taking my old gateway parts that are in my pc now and making a sff pc. ill be taking out my pent. D 820 cpu from this pc and then getting a new one. im not really planning on spending alot of money and maybe even getting a board off of ebay that will allow me to spend the least amount of money. so whats the cheapest socket 775 mobo that doesnt have tons of problems.
post the specs on the gateway as well, or what you are going totake from it at least
if you want to keep the video card then you need to tell us if its AGP or PCI-E.
if its ram, then what kind, no point in spending mroe money on a ddr2 800 Mobo if you only have DDR2 667 (just an example, i know they are basically the same price)
also, are you going to upgrade this in the future at all? or is it just htere as a second computer that you want running.
P.s.
http://www.newegg.com/Product/Product.aspx?Item=N82E16813186106
this is a good cheapo motherboard, i build a couple computers with it, dont expect alot of OC capiblities or anythign though.
