I'm getting really odd results from www.speedtest.net in the past couple of weeks. The AT&T tech replaced my ethernet socket, cable, and modem a couple of weeks ago, and my router settings were reset in the process. Since then when running the test on my mac laptop I'm getting these results with very few data points, often reporting zero mbps or 40 mbps for subsequent points, but ending up around an average of 10mbps.
Strangely, I'm not getting these herky jerky results on my iphone when running the speed test app. It displays what it should - a large number of data points falling within a fairly narrow range of speeds. Though I am also reporting abnormally slow speeds on the iOS app (around 7mbps).
I should be getting about 12mbps on each device, which is what I get on my ethernet connected PC. I've chosen the least busy wifi channel (1), but this doesn't seem to have alleviated the problem.
Link to screenshot of mac laptop results: http://imgur.com/5L8Ujra
Link to screenshot of iphone app results: http://imgur.com/AEGvKI3
