sorry for the help thread, but I'm not sure who else to turn to. I placed this in the MOBO section because I'm assuming it's the mobo, but I don't want to replace it without at least trying to consult someone else.
I just recently bought a new tower and radiator to upgrade from some junk tower and a thermaltake radiator that came with a kit. just about everything else is the same, I just moved from one tower to the other. Now, when I went to power it up I got nothing. realizing I had added a few more fans because of the tower switch it was probably just a little too much for my 550w PSU. so I upgraded that to a silverstone 850w. Yay works!...but...
This is the weirdest symptom I've seen. once I shut it down, I have to unplug it for a few minutes and plug it back in for it to turn on. otherwise I get a flash of juice or nothing....?
is it a bad batch of the PSU?
It is near time to replace the hardware, but I was hoping to wait until fall.
tower I'm using:
LIAN LI Lancool PC-K62 Black 0.8 mm SECC, Plastic + Mesh ATX Mid Tower Computer Case
and the PSU
SILVERSTONE ST85F-P 850W ATX 12V v2.3 / EPS 12V 80 PLUS SILVER Certified Modular Active PFC Power Supply
here is my out of date hardware:
ASUS P5KPL-AM/PS LGA 775 Intel G31 Micro ATX Intel Motherboard
Intel Pentium E5200 Wolfdale 2.5GHz LGA 775 65W Dual-Core Desktop Processor BX80571E5200 (with a weak overclock to 3.0 never breaking 45c)
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Dual Channel Kit Desktop Memory Model F2-6400CL5D-4GBPQ
the video card is even older, but I know that's not the problem.
also this is water cooled if that makes any difference on what I could have toasted or over stressed. It's a bigwater 735 kit with a video waterblock and a new 2x140mm radiator.
I am grateful for any tips/suggestions/ideas...anything. I'm at a loss as to what this is as it works...it's just odd.
tower I'm using:
and the PSU
