Whats better?
w00bi
Couldnt really find a better forum, it was either amd or intel..
So....
Whats better do you think?
Amd 64 3200+ or an Intel 3.2
I mean they are both around the $200 range, and that is what I am looking at, as of the moment. I dont want a amd 2500mobile and oc... I dont like oc.. I like stock
For games and general computing, go with the A64. If you are doing heavy mathematical or graphics work, go with the Pentium.
If your going to be keeping the PC for more then a year or two, i would recommend getting the AMD64.
