arnemetis said:1.525v....still really low.i ran up to 1.7v on stock without even worrying, and actually I almost regret getting the xp-90, almost wasnt worth it. Also, hope your psu is up to par, havent seen you mention that. Also you said it will run 250 with one stick...try it with the other, maybe one stick is defective.
MAngelo said:3200+ socket 939 A64
Gigabyte K8NS 939 mobo
MAngelo said:yes, alt-f1 gives you the memory settings, and other options, like the HTT multi. I dont know why Gigabyte buries this in the back page of the manual- its under FAQ in Troubleshooting. If you cant get past 216, drop HT to 4x or 3x, and depending on your ra, you may have to drop the divider for the ram.
