Whats a good replacement for the center speaker for z-5500s?
RooK
So my center speaker is no more...
I'm not looking to spend an outrageous amount (ie - over 50 bucks or so) for a decent center speaker to compliment my current z-5500's.
Anyone have a good suggestion? Ebay turns up Bose speakers that are just flat outrageously priced and I just won't spend that much on one speaker.
well i have a set of klipsch pro media 5.1 speakers in storage. the amp is screwed on the sub, but the sats work great. but honestly for the price of the z5500 id just replace the set unless youre stuck.
or you could ebay for a 680/z5500 they are essentially the same iom sure there are a few broken ones popping up every now and again
