I am looking for a good but inexpensive kvm. i got a vga monitor and ps2 keyboard and usb mouse. I dont need more than 1280x1024 resolution. any suggestions?
Thanks in advance
Dont know how cheap you want, but i spent about 100$ on a two port belkin KVM switch about two years ago... i'm sure price has dropped by now. The bulk of the expense was the damn cables... which you can usually find alot cheaper cables (same qaulity), at electronics parts stores such as www.digikey.com and www.jameco.com
my little two port belkin KVM switch accepts a ps/2 mouse and keyboard, but i use a USB mouse with an adapter with it with no problems.
I've been using one on my test bench at work for a few months now and it's worked flawless, built in keyboard swapping and you can set the switch to automatically swap between computers after 5, 10, 20 or 30 seconds. We got ours for $35 through our wholesaler.
I bought this one a few months back, the only thing I don't really like about it is that you need a usb to ps2 adapter and that it beeps when you switch but you can open the casing and remove <rip off> the little speaker. it is cheaply priced but good quality.
