What?
  • Thread starter Deleted member 143938
  • Start date
D
Guest
Last night my computer worked fine, this morning I boot it up and for some reason it won't detect my HDD... I go to the BIOS and notice every single thing is maxed out and changed around, the voltages, timings, everything. I am the only one using the computer and only my 9 year old sister and parents are in the house, my parents haven't come into my room because I would have heard them and they wouldn't know how to change the settings any way. My xPCI timings were changed to at least 107 mhz from the default 100 and so it must be the cause, so now my HDD is gone, everything else seems to be fine, I guess because the max voltages for the CPU to operate at are 1.550 before windows boots up, and then do 1.550x%136, and so the hard drive got messed up first. What the hell could have caused this? Hackers can't access BIOS and I don't go into any sites I don't know, no viruses.... I haven't ran nTune or any crap like that.. I changed the settings back to normal but my hard drive still won't boot... anyone can help?
And if something did mess up in the motherboard (by the way the computer is only 2 months old) how can I know once I buy the new HDD, this won't happen again in a week? :( :confused:
Edit: I also just noticed that if I save a profile and load it, it just loads random settings each time, so it's something with the motherboard as well, and resetting the CMOS doens't stop it from loading the random settings
Please do not use implied swearing like "WTF" in thread titles.
no way in the world could your pcie speed or your vcore harm your hard drive. pcie freq only controls the speed of your pci express slot/slots, and vcore only controls 12v voltage to your cpu. how do you figure this caused your hd to croak? and i got to tell you, the thing about the phantom overclcocking, well......
are any settings not relating to overclocking being changed? it sounds like a very selective glitch.
resetting the cmos will not clear out the the bios profiles, which is the whole point of "cmos reloaded" i think its called.
Well I read somewhere that overclocking the pci buses also overclocks the HDD conectors..
Every single thing got randomed in the BIOS, including the HDD settings like HDD spread specturm and stuff. I know CMOS won't clear the profiles but what I'm saying is that whenever I load a profile it always loads some random setting instead of what the profile is saved to... something is really messed up in this motherboard...
Most SATA controllers are linked through the PCIe bus.
Have you tried resetting your CMOS battery yet (by removing the big silver battery on the board)? You might have some BIOS corruption, which happens to me often.
Worst comes to worse, you might need to re-flash your BIOS, if you can ever get back into windows.
You rock!!!! Restting the CMOS with the switch didn't help, but now that I pulled the batttery (after all reseting the switch does the same thing, I thought) out and my computer boots
yup takeing out the battery does wonders.. especially when someone thinks there slick and password protects your computer from the bios... lol.. just take out the battery adn your in :D
What does this have to do with the op?
bottom line taking out the battery can fix alot of things in this case solving the problem of why his bios screws up... my experience was someone playing a prank on me by password protecting my comp through the bios.
