Hey guys
I'm curious to see what you would do in my case.
I made some upgrades to my machine one of them being a graphics card. First time around I chose a MSI 6970 Lightning after it was finally in stock. It worked the first week and then proceeded to not work by freezing and give me black screens. Upgrading the PSU to a Corsair AX850 did not solve the problem.
It upset me that this expensive card failed dam you msi/amd! Ok let's try Nvidia which is what I wanted in the first place. I then chose the Gigabyte GTX570 SOC (GV-N570SO-13I). My objective was a fast card that's quite. Fast with out me having to OC it. This was a good option.
This is what I have at the moment but the card makes me uneasy. In two or three ocassions it has failed to post when booting and doing the usual cable, seating, switching slots didn't really resolve the problem. It just started working again. The card presents no problems in windows.
So I submitted a ticket to Gigabyte to see what they would tell me. The response they gave me doesn't give me any confidence at all. This is what I'm paying almost $360+ for?
Here is the ticket:
Response to ticket:
Did I explain my self incorrectly in the ticket?
I feel like getting a refund for a second time with a different card manufacturer.
These "premium" cards don't feel like it at all.
Thanks for any input.
Here is the ticket:
Hello
I just bought this card and it works most of the time. The problem I'm having is that sometimes when I turn on the PC I get the bios error POST sounds: 1 long 2 short.
When that happens the video card's LED's don't light up or if they do they eventually turn off and the fans run at full speed or fast.
Here is what I've done:
Change PCI-E power cables.
Re-seat the card on the graphic slot.
Change graphic slot.
Use my old graphics card: ATI 4850, when I do this the computer works.
Then I reverted my motherboards bios from F14P back to version F13.
I re-install the GTX570 and it doesn't work.
I just leave the system for a bit...and try again.
Now the machine boots up. I have no idea why...
In windows doing benchmarks (kombuster for an hour, 3dmark 11, Heaven DX11) or playing games there aren't any lockups, artifacts, heat problems. Everything is fine. It's just booting up that it sometimes doesn't work.
I will continue to test with bios version F13 but I don't know if that could affect it.
Please advise what I should do.
Thanks!
Model Name : GV-N570SO-13I
PCB ver : 1
Driver Ver : 257.33
Serial No. : *****
Purchase Dealer : newegg.com
Motherboard Brand : GIGABYTE
Model : ex58-ud4p
Operation System : Win 7 64-bit SP : 1
6GB OCZ 1600Mhz
i7 920 stock
Crucial M4 128GB
Hitachi 2TB 7200RPM
DVD-R Drive
Corsair AX850 PSU
HAF 932 Case
Dell 2407WFP display
Motherboard bios: F14P
Response to ticket:
Dear Customer,
That relates to the video error code, have you tried moving the card over to the 2nd PCIe slot to test the results?
Also for the driver please use the latest directly off nvidia website and test with DX10 instead of DX10 by removing it and reloading DX10
