N
NecessaryEvil
Guest
A server is to be built.
P4 2.4-2.66ghz (P4B)
1gb PC-2100
adequate harddrive space (a single 80, most likely)
DVD-ROM
vidcard w/ DVI.
This will host BF42 & COD games & LANs, and on the T1 line @ my apartment. Any file serving will be done w/ my external firewire enclosure, as that's where my movies & mp3s are.
there are two paths for me to take.
the universal path...and the dedicated path.
the Universal path gives me this:
regular ATX tower.
Abit IS7 motherboard
plenty of expansion
the Dedicated path gives me this:
Shuttle XPC
845G motherboard
limited expansion
Now, all I need this system to do is run 1 hdd(maybe 2), a DVD-ROM (I'll have a DVD burner hooked up externally as needed), and have 2 network cards (1 onboard for LAN maintenance, 1 PCI for WAN serving)
Here are the pros & cons
Pros:
Universal:
more expansion capability
cheaper
Dedicated:
Easier to take to LANs
I can stuff it under my bed.
I can set it on top of my UPS
I can stack the cubes. (my SB65G2 could go on top of or underneath the server, and secured via straps) (any help I can get is worthwhile at LANs, since I have 20" LCD to take with me)
Cons:
Universal:
size
noise (potentially)
requires upfront purchase of vidcard
Dedicated
limited expansion
more expensive
so, I'm basically weighing between the lesser of the evils.
What would you do?
The LAN friendly Shuttle? or the Jack-Of-Trades Tower?
1gb PC-2100
DVD-ROM
vidcard w/ DVI.
regular ATX tower.
plenty of expansion
Shuttle XPC
845G motherboard
limited expansion
Pros:
Universal:
cheaper
Dedicated:
Cons:
Universal:
size
noise (potentially)
Dedicated
limited expansion
more expensive
What would you do?
