Cold Dark Shadow
- Mar 24, 2003
Update 11.20.08
Update 2:
Stucka new corsair PSU in it to see if that was the issue and nothings changed
This is 2nd card i got from eVGA for an RMA, this one i got the 17th of this month. the last one (2nd pic) lasted a week maybe
Temps are all down 50C or below under load (fan turned up) and no OCing
Ok got the RMA card installed worked just fine for half the daythen this this...
the vid is all chuggy now as well ans will freeze upand then compe back lookin worse then the pic below and if it does hold the picture and not get all funky the FR will drop to single digits
Other then the vid card what can cause this? i need ideas cause theres no way i got another bad card.....
Started doin that a few minutes ago and only while gaming, websurfing its just fine.
Taking after a PSU swap
Update 2:
