What would cause a PC to not turn on?
vitalym
Worked fine last night before turning it off.
This morning it would not turn on. The mobo power light is on, so there is power...
Any ideas/tips/tests I could try to narrow down the issue, could there have been a short when turning it off?
Try turning off the power supply and then replugging the power cord. That seems to fix it for me whenever it just hangs on boot when nothing is wrong with the hardware.
if its a laptop, reseat your harddrive, because I was stuck on the back screen because my harddrive got unseated during transport.
Unplug anything you dont need to boot and see if it improves.
Try one memory stick and different ram slots.
Could be a faulty power button. Try jumping the pins on the motherboard by using a screwdriver to turn the computer on.
I should have been more specific.
It's a desktop and I've tried unplugging it for a while and plugging it back in.
