Namelessme
- Jan 3, 2012
I wasn't around here back when the 2490 A-TW was discontinued, and am just wondering what was the official reason NEC gave for discontinuing use of the A-TW polarizer in any models? Was it simply a problem obtaining that part anymore? Or was it too expensive?
I'm mostly curious as I happened to be looking at Kindle Fire HDs, and noticed this little blurb:
Like many tablets, Kindle Fire HD uses In-Plane Switching (IPS) to improve color reproduction. But displays that only use IPS still appear washed out at various angles, such as laid sideways when reading in bed, laid flat on a table, or held between you and a friend when sharing a movie. Kindle Fire HD addresses this issue by applying an advanced polarizing filter directly to the LCD panel. This results in a display that shows the same deep contrast and rich, detailed color when viewed at any angle
And that sounds basically like the same thing as the A-TW polarizer used in a handful of 90 series NEC monitors. I wouldn't think it super expensive to add then, as if Amazon can afford to put it in a $200 tablet, how expensive can it be really? And evidently it's still possible to buy from a source somewhere.
I guess I just find it weird how nobody seems to be using A-TW anymore, as if a manufacturer released a decent monitor with A-TW, and ideally without PWM, I think they'd clean up ... a lot of people here I think would really be interested in such a monitor. No IPS glow, no flicker... perfect angles.
