What wall mount
Being capable of 77lbs it is a bit large for a 22 isn't it? If you mount a 22 on this mount, you may be able to see the mount sticking out from behind the monitor which wouldn't be too pretty. Get something smaller more suited to a 22 like this one:
http://www.geeks.com/details.asp?invtid=WLB001&cat=MON
or this:
http://www.geeks.com/details.asp?invtid=WLB272&cat=MON
I have a 37 on an arm type mount like the 2nd one (heavier duty of course since it's a 37 and not a 22) and I like it a lot. You can move the monitor around easily and get to the back of it if you need to.
for some reason, i checked the back of my westinghouse monitor and it doesn't have mounting holes
WTF? its a 22incher it should right?
