what voltage to cpu question
bup23
ok new post about the opteron 185,,my asus a8n32 puts it at 1.4 volts..i read the opteron is supposed to at 1.3 or 1.35 volts..so i manually put it at 1.35..is that ok??im not planning on overclocking..is it safer at 1.3 volts?or is it ok at 1.35?thx
I think 1.35 is the safest choice, could try to check if 1.3 or 1.325 are stable. No harm in running a lower voltage if it's stable, you get cooler temperature.
