What video card?
Phantom25
What gaming video card do you think i should get and would go the best with my system specs:
- MB: ASUS P5ND2-SLI NVIDIA nForce 4 SLI
- CPU: Intel Pentium D 805 2.66GHZ
- RAM: 3GB DDR2
What games do you play, what resolutions do you play said games, what is your budget and what power supply are you using?
i have a 465W atx powersupply right now, but if needed i will buy new one. I would like to play like gta4 or crysis on 1024x768 resolutions high settings, around 100$ or more.
for 1024x768, i wouldn't look much higher than those. Although you can find a deal or two on those older cards, some 'newer' gen-cards at the same price-point (or lower) are just as capable.
465W may handle a card like that - depending on it's true power output / brand etc
It wouldn't hurt to run your system through a PSU calculator to get an idea of where you're at.
