What Video Card???
Hello just scooped a Dell 2405FWP OMG!!!!!!! I love this monitor. Well it made me want to get into gaming. I like the game COD2. What card can I run with this computer (specs below) for say under 150?? Used is fine so if u have something cool I will take it
Gigabyte K8nf-9 MOBO (24) pin
AMD 64 3000+ Venice core
Kingston BH-5 Ram 2x512 matched
audigy2 ZS sound card
NEC 3550A DVD RW
X600XT Gold PCI-E x16 (can I upgrade this card???)
OC Core Speed 1981.6MHz
HTT 220.2MHz
Multi x9
RAM
Cas Lat 2
RAS to CAS 2
RAS Pre 2
Tras 11
TRC 11
DRAM Idle Timer 16
220.2MHz Dual Channel
Voltage steady @ 1.456v
Thanks for ur help let me know if u need anymore info
I'm gunna suggest a 6800GT, as you wont see a huge performance increase between that and a 7800GT because your Bottle neck is probably your CPU.
Acidzerocool said:
Can i max out everything in COD2 with it?
No. Your CPU and RAM will stop you from reaching that Card's full potential. :/
High Settings MAYBE
*edit* Didnt see your price constraint. No way you'll find something to max out a game at that price :/
High Settings MAYBE
K thanks just trying to learn what about gaming know nothing about it
Lol its cool man. I picked up a BFG 6800OC on here for $150. Shoot for that. I can run BF2 @ Med-High settings, and I'm only on socket A.
Is COD2 a more in depth game then BF2 like say for lack of words a harder game to run?
Also the x600xt anything i can do with it??
No Idea. You will not beable to run either (high or maxed) for $150 though, i can tell you that :/
No. I believe its actually WORSE than the 6800 OC. :/
jcll2002 said:
i think its pretty much the same...not sure though
No. the 6800GT Is better.
Yes, for your price range ACID, get that I guess. Dont expect uber high settings on the game though.
You won't be able to max out COD2 on a Dell 2405 with an AGP card.
In fact you would at least need a $300 7800GT PCI-E, if not more.
Using PCI-E read above specs
For around $200...PCI-E 6800GS.......Is where it's at....
Thats about as low as you can go to run COD2 ANYTHING like you want it....It still wont be maxed out though :/
Thanks for the input what about a 6600GT OC I can get that for $85 will that suit my needs?
I just want to be able to play at a decent res with my 2405 and decent features nothing to crazy just good enough for me to try out the gaming scene if u know what i mean.
Expect Med Settings with that. Nothing more, really.
Nice card for the price though :)
yeah I would just go for the 6600gt for that price. best bang for buck if ur getting under 100.
